BIG-IP 9.4.5 Build 1086.1 Hotfix HF2
I have enabled ramcache on a profile applied to a VIP.
For the ignore headers option I have chosen None which Specifies that the system honors all Cache-Control headers. All others setting are default so the max age setting on the F5 is 60mins.
On the application that is passing through the VIP the max age header is set to 30mins. This header passes correctly to the browser but when I look at the cache on the F5 itself it uses the default max age and not the one set from the browser.
I want the F5 to behave like a public cache and honor the settings from the application. Has anyone come across this before?
On another aside I have come across different versions of the meaning of some of the settings.
For the option Cache-Control:max age the help on the F5 has the following “Cache-Control:max-age: Specifies that the system acknowledges only the Cache-Control:max-age header.” While from documentation on the site I found the opposite “Specifies that the system ignores only the Cache-Control:max-age header.”
Tks,
D
