ram cache problem1
Hi, I configured a web acceleration profile with the 600 seconds max age value. when i look at the response from the server ( bigip vs) i see that the cache control max-age value 604800 and also see a age header that is value 495. I confused that which header (age ,cache control) i should consider that is max age value for contents and which is sent by the bigip?
Cache Age: 495 Cache-Control: max-age=604800,public Date:Wed, 04 Jun 2014 06:11:22 GMT
Thanks,
Hi!
Had a discussion with F5 regarding this a few months ago. According to the technician I talked to the LTM performs OR logic to determine if cached entree is subject to revalidation evaluating “maximum age” and cache-control header in server’s response. In another words if “maximum age==180” but cache-control: max-age==60", LTM will revalidate the content after 60 seconds.
The cache-control: max-age might not be rewritten by the ltm because it keeps it’s own records. You can check the entries by issuing the following command:
show ltm profile ramcache
You should be able to verify this in the IIS log by checking how often the cached documents are fetched by the load balancer.
/Patrik
Hi Patrik, Thanks for your response. I have an another issue that automate removing cache content on the f5 when app. servers content was changed. Because i dont want to wait until max. age value expiration for the cached object in the web accleration profile so I want to do this process immediately. is it possible wit an irule ?
Thanks,
Mind that I have not tested this myself and I am currently not in position to do so, but I reckon you can use this method:
I imagine you can combine it with a custom header or cookie to set expiration.
Example (not tested or checked for syntax and painfully written on an iphone):
   if { [HTTP:header exists expirecache] } {
      set cacheexp 1
when CACHE_RESPONSE {
  if { [info exists cacheexp] && $cacheexp == 1 } {
    CACHE::expire
Note: If you don’t want strangers invalidating your cache you might want to filter by ip as well. :slightly_smiling_face:
/Patrik
