can I raise events from my iRULE code
like raise HTTP_success or HTTP_fail etc
Thanks,
karthik
Thanks,
karthik
No. There is no support for raising events from an iRule. Okay, well, there’s one exception. The TCP::notify command will raise a USER_REQUEST or USER_RESPONSE event. However, this command is undocumented and difficult to use correctly. What are you trying to do?
I would like to raise the event AUTH_SUCCESS, so that I can skip authentication network call for request subsequent to initial login.
Thanks,
Karthik
