I have a need to create a radius monitor. The canned radius monitor will not suffice because we can not use a static password. I can specify a valid username but will use an invalid password which will result in an Access-Reject. Is it possible to build a radius monitor that will consider an Access-Reject ok and keep the nodes marked up.
Hi Steve, did you find a solution? Looking for the same.
How about creating an advanced monitor using netcat?
I have opened a RFE for this:
RFE 445480 - Radius Monitor should mark member up even with Access-Reject
No ETA..
