Problem this snippet solves:
RADIUS authentication library that facilitates development of complex full proxy RADIUS auth solutions. Links a RADIUS request with a response and validates the RADIUS response authenticator as well as any Message-Authenticator attribute if present.
This started out as an attempt to refactor “RADIUS server using APM to authenticate users”. It has since proved really powerful so I wanted to share it in case others gain ideas from it or have any feedback.
It’s not specifically tuned for performance since you could say I initially set about to untune Stanislas’ work in order to make some iRules easier to maintain. It should still perform reasonably well considering there’s not a whole lot of code in there. The focus was to ensure it would be robust and secure.
How to use this snippet:
Save this irule in /Common/RADIUS_AUTH. It doesn’t require a radius profile.
Read the comments for usage details. If you are ever expecting an error condition, be sure to wrap your calls in a “catch” command and check the global $::errorCode value.
Increase the timeout variable if it’s too short for your RADIUS client.
Code :
# RADIUS_AUTH - Version 1.0.1 - 2018-11-01
# Procedures used to manipulate RADIUS authentication packets with support
# for Authenticator validation as well as Message-Authenticator.
# Tested on BIG-IP LTM 12.1.2
# Supported RADIUS codes:
# 1: Access-Request
# 2: Access-Accept
# 3: Access-Reject
# 11: Access-Challenge
# Installation: Create this irule as /Common/RADIUS_AUTH
# Usage:
# Generally, when CLIENT_ACCEPTED call "parse_packet" to get information about
# an Access-Request from a RADIUS client. The AVP array can then be manipulated
# and a new packet generated in order to either replace the payload sent to the
# server or drop the packet and respond directly.
# AVP array now uses a floating point multiple value index. The type code is
# the integer component, the value after the decimal point is the sequence in
# which it was read from the payload. In this manner, you could use for example
# [array get AVP 18.*] to list all Reply-Message attributes in case there are
# multiples. If you only care about the first instance of an attribute,
# remember to use the float values like AVP(18.0) as AVP(18) would not be set.
# When working with Message-Authenticator, a key must be provided. Failure to
# validate a Message-Authenticator will result in an error.
# There is no need to supply the Request Authenticator via the optional req_auth
# parameter as long as the Access-Request went through parse_packet and you
# generate a response before the timeout removes the entry from the table.
# You can use RADIUS_AUTH to some extent in conjunction with RADIUS::avp. Avoid
# using RADIUS::avp to change values on packets that use Message-Authenticator.
# Shortcomings:
# This library is concerned mostly with validating the packet structure.
# In terms of RFC compliance, this library doesn't do any validation of AVP
# values (other than Message-Authenticator). The table used to store request
# authenticators assumes you are only using this with a single RADIUS virtual
# server. If you use this library with many RADIUS virtual servers, move the
# "static::RA_table" declaration out of here and into irules specific to
# those servers with a unique value for each.
# The F5 supplied RADIUS library has good support for vendor AVPs. However, if
# you do have a need to use RADIUS_AUTH for this, here's an example that
# iterates through all the vendor specific AVPs:
# foreach {idx val} [array get AVP 26.*] {
# binary scan $val Ia* vid bin_data
# set output " Vendor($vid) "
# call RADIUS_AUTH::avp_bin2array $bin_data VAVP
# if {[array size VAVP] > 0} {
# foreach vi [array names VAVP] {
# append output "VAVP($vi): $VAVP($vi); "
# } else {
# append output "VAVP(raw): $bin_data; "
# log local0. $output
# The ability for me to assemble this library was very much thanks to the APM
# RADIUS server published by Stanislas Piron (whome in turn thanks John McInnes
# for his prior work and Kai Wilke for further assistance).
# Project home: https://github.com/CharlesDarwinUniversity/RADIUS_AUTH
when RULE_INIT {
set static::RA_timeout 10
set static::RA_table "RADIUS_AUTH"
set static::RA_pp_err "RADIUS_AUTH::parse_packet ERROR"
set static::RA_gp_err "RADIUS_AUTH::generate_packet ERROR"
set static::RA_errm(0) "OK"
set static::RA_errm(1) "Malformed RADIUS packet"
set static::RA_errm(2) "Malformed RADIUS AVP data"
set static::RA_errm(3) "Key is requred to validate RADIUS response packet"
set static::RA_errm(4) "Request Authenticator not found, can not validate response packet"
set static::RA_errm(5) "Failed to validate RADIUS response authenticator"
set static::RA_errm(6) "Invalid Message-Authenticator or wrong key"
set static::RA_errm(7) "Invalid or unsupported RADIUS auth code"
# RADIUS_AUTH::parse_packet payload ?key? ?out_avp? ?out_username? ?req_auth?
# Validates the payload and returns the RADIUS code when valid. Populates an
# output parameter with the AVP data as an array of multi-value type codes.
# Note: Doesn't return the packet ID becuase you can simply use RADIUS::id or
# binary scan.
# "out_username" is populated with User-Name. If this is a response code, and
# User-Name was not supplied it will lookup the stored Access-Request User-Name
# value (RFC2865 hints that the response User-Name could be preferred).
# Example usage:
# set code [call RADIUS_AUTH::parse_packet [UDP::payload] $key avp]
proc parse_packet { payload {key ""} {out_avp ""} {out_username ""} { req_auth "" } } {
if {$out_avp ne ""} { upvar $out_avp AVP }
if {![array exists AVP]} { array set AVP {} }
if {$out_username ne ""} { upvar $out_username USER_NAME }
if { [catch {
if { [binary scan $payload ccSa16 CODE IDENTIFIER PKT_LEN AUTHENTICATOR] != 4 \
|| [set PKT_LEN [expr {$PKT_LEN & 0xFFFF}]] > [string length $payload] || $PKT_LEN > 4096} {
error $static::RA_pp_err $static::RA_errm(1) 1
# Length field is valid (less than 4096 and less than payload length).
# Octets outside the range of the Length field MUST be treated as padding and ignored on reception.
set PAYLOAD [string range $payload 0 $PKT_LEN]
set IDENTIFIER [expr {$IDENTIFIER & 0xFF}] ;# Unsigned (compatible with RADIUS:id)
# Support RADIUS auth codes only...
switch -- $CODE {
1 - 2 - 3 - 11 {
if {$PKT_LEN > 20} {
# Stores all attribute in AVP array with multiple value index of the format TYPE.SEQUENCE...
call RADIUS_AUTH::avp_bin2array [string range $PAYLOAD 20 end] AVP msg_auth_offset
if { [array size AVP] == 0 } {
error $static::RA_pp_err $static::RA_errm(2) 2
if { $msg_auth_offset > -1 } {
set record_offset [expr {$msg_auth_offset+20}]
binary scan [string replace $PAYLOAD $record_offset \
[expr {$record_offset + 18}] [binary format ccH32 80 18 [string repeat 0 32]]] a* UNSIGNED_PAYLOAD
} elseif { [array exists AVP] } {
array unset AVP
if {![array exists AVP]} { array set AVP {} } ;# Make sure we have an AVP array, even if it's empty
set USER_NAME [expr {[info exists AVP(1.0)] ? $AVP(1.0) : ""}]
# Process the authenticator...
if { $CODE == 1 } { # Access-Request code...
set req_auth $AUTHENTICATOR
# Store Request Authenticator and User-Name for later...
table set "$static::RA_table.[IP::client_addr].$IDENTIFIER.RA" $AUTHENTICATOR $static::RA_timeout $static::RA_timeout
table set "$static::RA_table.[IP::client_addr].$IDENTIFIER.UN" $USER_NAME $static::RA_timeout $static::RA_timeout
} else { # RADIUS response codes...
if { $key eq "" } {
error $static::RA_pp_err $static::RA_errm(3) 3
if { $req_auth eq "" } {
set req_auth [table lookup "$static::RA_table.[IP::client_addr].$IDENTIFIER.RA"]
if { $req_auth eq ""} {
error $static::RA_pp_err $static::RA_errm(4) 4
set resp_auth [md5 [binary format ccSa16a[expr {$PKT_LEN-20}]a[string length $key] $CODE $IDENTIFIER \
$PKT_LEN $req_auth [string range $PAYLOAD 20 end] $key ]]
if { $resp_auth ne $AUTHENTICATOR } {
error $static::RA_pp_err $static::RA_errm(5) 5
if { [info exists AVP(80.0)] } {
# Patch Request Authenticator into UNSIGNED_PAYLOAD (see rfc2869, page 34)
binary scan [string replace $UNSIGNED_PAYLOAD 4 19 $req_auth] a* UNSIGNED_PAYLOAD
# If supplied, validate the Message-Authenticator...
if { [info exists AVP(80.0)] && \
($key eq "" || ![CRYPTO::verify -alg hmac-md5 -key $key -signature $AVP(80.0) $UNSIGNED_PAYLOAD]) } {
error $static::RA_pp_err $static::RA_errm(6) 6
# Response doesn't contain User-Name, populate it from the Access-Request value...
if { $CODE != 1 && $USER_NAME eq "" } {
set USER_NAME [table lookup "$static::RA_table.[IP::client_addr].$IDENTIFIER.UN"]
default {
error $static::RA_pp_err $static::RA_errm(7) 7
}]}{ # Clean the out parameters on error
array unset AVP *
set USER_NAME ""
error $static::RA_pp_err $::errorInfo $::errorCode
return $CODE
# RADIUS_AUTH::generate_packet code id key ?in_avp? ?force_msg_auth? ?req_auth?
# Returns a valid RADIUS packet payload.
# Example usage:
# set payload [call RADIUS_AUTH::generate_packet $code $id $key avp 1]
proc generate_packet { code id key {in_avp ""} {force_msg_auth 0} { req_auth "" } } {
if {$in_avp ne ""} { upvar $in_avp AVP } else { array set AVP {} }
set req_auth [table lookup "$static::RA_table.[IP::client_addr].$id.RA"]
error $static::RA_gp_err $static::RA_errm(4) 4
# Remove the Message-Authenticator, setting the flag to reinsert it later
set force_msg_auth 1
unset AVP(80.0)
set bin_AVP [call RADIUS_AUTH::avp_array2bin AVP]
set packet_length [expr { [string length $bin_AVP] + 20 }]
if { $force_msg_auth==1 } {
set UNSIGNED_AVP $bin_AVP[binary format ccH32 80 18 [string repeat 0 32]]
incr packet_length 18
append bin_AVP [binary format cc 80 18][CRYPTO::sign -alg hmac-md5 -key $key [binary format ccSa16a* \
$code $id $packet_length $req_auth $UNSIGNED_AVP]]
if { $code==1 } { # Access-Request code...
set authenticator $req_auth
} else { # Assuming RADIUS response codes ( we could add $code validation here )
set authenticator [md5 [binary format ccSa16a[expr {$packet_length-20}]a[string length $key] \
$code $id $packet_length $req_auth $bin_AVP $key ]]
return [binary format ccSa16a* $code $id $packet_length $authenticator $bin_AVP]
# RADIUS_AUTH::avp_array2bin in_avp ?unsign?
# Returns the RADIUS binary string formatted representation of an AVP array.
# Unless "unsign" is set to 0, any Message-Authenticator value will be
# replaced with zeros as any value would be meaningless in this context.
# Example usage:
# set binary_avp [call RADIUS_AUTH::avp_array2bin avp]
proc avp_array2bin { in_avp {unsign 1} } {
upvar $in_avp AVP
set binary ""
foreach mv_idx [array names AVP] {
set avp_type [expr {int($mv_idx)}]
if { $avp_type != 80 || $unsign == 0 } {
set avp_len [expr {[string length $AVP($mv_idx)]+2}]
append binary [binary format cca* $avp_type $avp_len $AVP($mv_idx)]
if { [info exists AVP(80.0)] && $unsign == 1 } {
# Insert the unsigned Message-Authenticator
append binary [binary format ccH32 80 18 [string repeat 0 32]]
return $binary
# RADIUS_AUTH::avp_bin2array binary out_avp ?out_msg_auth_offset?
# Interprets "binary" as RADIUS AVP data and populates the array specified by
# the output parameter "out_avp".
# "out_msg_auth_offset" is used to get the offset of the Message-Authenticator
# in the binary data incase you want to know if it exists or unsign it. This
# feature is really only here to make packet parsing a little more efficient.
# Example usage:
proc avp_bin2array { binary out_avp { out_msg_auth_offset "" } } {
upvar $out_avp AVP
if {[array exists AVP]} { array unset AVP }
if { $out_msg_auth_offset ne "" } { upvar $out_msg_auth_offset msg_auth_offset }
set msg_auth_offset -1
set bin_len [string length $binary]
array set multi_value_index {}
for {set avp_offset 0} {$avp_offset < $bin_len } {incr avp_offset $avp_len} {
if {([binary scan $binary @${avp_offset}cc avp_type avp_len] != 2) || ([set avp_len [expr {$avp_len & 0xFF}]] < 3) \
|| ($avp_offset+$avp_len > $bin_len) } {
# This is not valid AVP data, trash the array and bail...
array unset AVP
break
set avp_type [expr {$avp_type & 0xFF}]
if { $avp_type==80 } { set msg_auth_offset $avp_offset }
if {![info exists multi_value_index($avp_type)]} { set multi_value_index($avp_type) -1 }
set mv_idx "$avp_type.[incr multi_value_index($avp_type)]"
binary scan $binary @${avp_offset}x2a[expr {$avp_len -2}] AVP($mv_idx)
if { not([array exists AVP]) }{ array set AVP {} }
# RADIUS_AUTH::pw_decrypt key req_auth encoded_password
# Decryption algorithm for User-Password attribute, contributed by Stanislas
# Piron.
# Returns the decrypted password.
# Example usage:
# binary scan [UDP::payload] @4a16 req_auth
# set pw [call RADIUS_AUTH::pw_decrypt $key $req_auth $AVP(2)]
proc pw_decrypt { key req_auth encoded_password } {
binary scan [md5 $key$req_auth] WW bx_64bits_1 bx_64bits_2
binary scan $encoded_password W* encoded_password_w_list
set password_list [list]
foreach {cx_64bits_1 cx_64bits_2} $encoded_password_w_list {
lappend password_list [expr { $cx_64bits_1 ^ $bx_64bits_1 }] [expr { $cx_64bits_2 ^ $bx_64bits_2 }]
binary scan [md5 $key[binary format WW $cx_64bits_1 $cx_64bits_2]] WW bx_64bits_1 bx_64bits_2
binary scan [binary format W* $password_list] A* password
return $password
# RADIUS_AUTH::pw_encrypt key req_auth password
# Encryption algorithm for User-Password attribute, contributed by Stanislas
# Piron.
# Returns the encrypted password.
# Example usage:
# set AVP(2) [call RADIUS_AUTH::pw_encrypt $key $req_auth "my password"]
proc pw_encrypt { key req_auth password } {
binary scan [binary format a[expr {[string length $password] + 16 - [string length $password]%16}] $password ] W* password_w_list
set encoded_password_list [list]
foreach {px_64bits_1 px_64bits_2} $password_w_list {
lappend encoded_password_list [expr { $px_64bits_1 ^ $bx_64bits_1 }] [expr { $px_64bits_2 ^ $bx_64bits_2 }]
binary scan [md5 $key[binary format W2 [lrange $encoded_password_list end-1 end]]] WW bx_64bits_1 bx_64bits_2
binary scan [binary format W* $encoded_password_list] A* encoded_password
return $encoded_password
# RADIUS_AUTH::ipv4_to_octets ip
# Useful for manipulating IPv4 attributes such as NAS-IP-Address
# Returns the 4 byte representation of an IPv4 string
proc ipv4_to_octets {ip} {
set octets [split $ip .]
foreach oct $octets {
if {$oct < 0 || $oct > 255} {
set octets [list 0 0 0 0]
break
if { [llength $octets] != 4 } { set octets [list 0 0 0 0] }
return [binary format c4 $octets]
Tested this on version:
12.1
