RADIUS Auth
Hi, I have followed the guide on remote user auth but I have an issue, the users with administrator role can login just fine, but none of the others can (guest and auditor)
In the F5 external users group I have this:
Attr string: F5-LTM-User-Info-1=mgmt
Assigned Role: %F5-LTM-User-Role
Partition access: %F5-LTM-User-Partition
terminal access: %F5-LTM-User-Shell
In RADIUS  we have this for admins
match user group “F5-Admin”
0,all,enable,tmsh,mgmt
and this for guests:
match user group “F5-Guest”
700,all,enable,disable,mgmt
When a guest logs in it just says failed login attempt. I tried creating a second external users group called guests and looked for “Attr string: F5-LTM-User-Role=Guest” which also did not work and have now removed.
Any ideas on where I am going wrong? I ran radius debugging but it did not show anything useful.
Does your radius debugging show that the user is authenticating to the RADIUS server?
yes it does seem so, this is the log:
pam_radius_auth: pam_radius_auth: user <username> not authenticated
I think radius side is wrong, does this look correct? Admin is exactly the same but with 0 instead of 700.
