Hi Experts, This is my first rule - you know what this mean
OK - the goal is to have pool member selection based on RADIUS attribute. I have on my box:
when RULE_INIT {
set static::debug_custom_attribute 1
set static::pool_name POOL_RADIUS_auth
set static::pool_odd_member 192.168.36.1
set static::pool_even_member 192.168.36.2
when CLIENT_DATA {
set nasip [RADIUS::avp 4 ip4]
set callingId [RADIUS::avp 31 "string"]
set is_odd [expr $callingId & 1]
if { $is_odd } {
Calling-Station-Id is odd
trying to select odd_member of the pool
pool $static::pool_name member $static::pool_odd_member
if { [LB::status node $static::pool_odd_member] eq "down" } {
log local0. "Pool: $static::pool_name member: $static::pool_odd_member -> is down switching to: $static::pool_even_member"
pool $static::pool_name member $static::pool_even_member
if { $static::debug_custom_attribute } {
log local0. "Calling-Station-Id: $callingId is odd"
Calling-Station-Id is even
trying to select even_member of the pool
if { [LB::status node $static::pool_even_member] eq "down" } {
log local0. "Pool: $static::pool_name member: $static::pool_even_member -> is down switching to: $static::pool_odd_member"
log local0. "Calling-Station-Id: $callingId is even"
But this is not working as I want. Could someone help me to mak it working? Thanks
what happens when this rule handles your traffic?
This is the problem nothing
It seams that LB_SELECTED event is faster then whole iRule … Please find below log: Jan 28 18:34:55 roz-1 info tmm[8604]: Rule /Common/F5_EvenOdd : Selected /Common/POOL_RADIUS_auth 192.168.36.1 1812 Jan 28 18:34:55 roz-1 info tmm[8604]: Rule /Common/F5_EvenOdd : NAS-IP-Addr: 192.168.1.10 Jan 28 18:34:55 roz-1 info tmm[8604]: Rule /Common/F5_EvenOdd : Calling-Station-Id: 420730175222 Jan 28 18:34:55 roz-1 info tmm[8604]: Rule /Common/F5_EvenOdd : Calling-Station-Id: 420730175222 is even Jan 28 18:34:55 roz-1 info tmm[8604]: Rule /Common/F5_EvenOdd : LB::Server: 192.168.36.1 Jan 28 18:34:55 roz-1 info tmm[8604]: Rule /Common/F5_EvenOdd : Server connected
Hmmm… Why is the load balancing logic in CLIENT_DATA, you’re sure that’s correct event? How is the UDP profile configured? with datagram load balancing? do you have RADIUS profile too? Are you saying the virtual server works fine, except traffic is not load balanced as you expect it to be?
Mohamed, to be honest - I don’t know if this is correct or not. Can I access Radius attributes on other event? Which event is the best for that? Please have a look on my VS configuration below: ltm virtual VS_RADIUS_auth_1812 { description “Virtual server for AUTH” destination 10.49.36.4:radius ip-protocol udp mask 255.255.255.255 pool POOL_RADIUS_auth profiles { udp { } } rules { F5_EvenOdd } source 0.0.0.0/0 source-address-translation { type automap } vlans { external } vlans-enabled vs-index 7 } F5 is doing LB just fine (I mean - the load is spread across two Radius servers in Round Robin - configured inside the pool). But this is not my goal - I repeat I need to send all even Calling-Station-ID to one server and odd Calling-Station-ID to another. Is there any other possibility to achieve this?
OK - maybe this is not the optimal, but when I changed the event to CLIENT_ACCEPTED I was able to change the pool and its member according to any RADIUS attribute. Mission acomplished
Yes, thank you Mohamed - it was very inspiring to me. Finally my iRule is looking like this one:
when RULE_INIT {
set static::version 1.0
set static::auth_pool POOL_RADIUS_auth
set static::odd_member 192.168.36.1
set static::even_member 192.168.36.2
when CLIENT_ACCEPTED {
Displays script version
log local0. ">>>> iRule script version: $static::version"
getting the Calling-Station-ID from the Radius packet
check if the callingId has any value
if { $callingId ne ""}{
checking Calling-Station-ID as callingId priority
if { $is_odd } {
pool $static::auth_pool member $static::odd_member
pool $static::auth_pool member $static::even_member
there is no Calling-Station-ID set in Radius packet
log local0. "Radius packet hasn't got Calling-Station-Id set"
we do normal load balancing around servers defined in pool
when LB_FAILED {
triggered when selected server is down
log local0. "Selected server: [LB::server addr] is down"
doing normal new server election from the pool
LB::reselect
for DEBUG only
when LB_SELECTED {
triggered when new server is selected: "manually" or by re-election
log local0. "New server selected: [LB::server addr]"
when SERVER_CONNECTED {
triggered when selected server is connected
log local0. "Server connected: [IP::remote_addr] from: [IP::local_addr]"
