RADIUS and route domain
Hello.
Platform: F5 BIGIP 3600, 10.0
Radius authentication doesn’t seem to work if radius server _located in route domain_ (and radius server address with % sign has no effect at all). The ip connectivity is working right (icmp, ip) but radius auth packets are going with such kind errors:
with % sign:
Oct 25 02:34:21 local/f5a err httpd[5247]: pam_radius_auth: Failed looking up IP address for RADIUS server 10.35.2.73%3 (errcode=9)
Oct 25 02:34:21 local/f5a err httpd[5247]: pam_radius_auth: All RADIUS servers failed to respond.
without % sign:
Oct 25 02:38:09 local/f5a err httpd[17866]: pam_radius_auth: RADIUS server 10.35.2.73 failed to respond
Oct 25 02:38:12 local/f5a err httpd[17866]: pam_radius_auth: RADIUS server 10.35.2.73 failed to respond
Oct 25 02:38:15 local/f5a err httpd[17866]: pam_radius_auth: RADIUS server 10.35.2.73 failed to respond
Oct 25 02:38:18 local/f5a err httpd[17866]: pam_radius_auth: RADIUS server 10.35.2.73 failed to respond
Oct 25 02:38:18 local/f5a err httpd[17866]: pam_radius_auth: All RADIUS servers failed to respond.
route-domain 3 {
description VRF3
vlans {
PRIVATE
self 10.35.2.78%3/24 {
allow-service default
vlan PRIVATE
radius system-auth {
servers {
system_auth_name1
radius-server system_auth_name1 {
secret xxxxxxxxxx
server 10.35.2.73%3
RADIUS-SERVER ping 10.35.2.78
PING 10.35.2.78 (10.35.2.78) 56(84) bytes of data.
64 bytes from 10.35.2.78: icmp_seq=1 ttl=255 time=0.000 ms
64 bytes from 10.35.2.78: icmp_seq=2 ttl=255 time=0.000 ms
Is that a bug or a feature?
Is this for client VIP or admin GUI/CLI auth? If client auth, I’d say it’s a bug--you should be able to specify an auth server in the VIP’s routing domain. If it’s admin auth, I don’t think it would make sense to have all admins authenticated against one routing domain’s auth server. For admin, wouldn’t it make more sense to define the auth server in the default routing domain?
Either way, I’d suggest opening a case with F5 Support to check on this. If you do/have already, could you post back what you find? If you get stuck, I can also check with a customer who set up admin auth with a RADIUS server and routing domains.
Aaron
