Under what circumstances would the source affinity entry not age ?
I have cookie insert as persistency and source_addr as backup. People only ever get to one of two servers being balanced (round robin) changes from day to day.
I’m going to disable fallback persistency and maybe create a oneconnect profile.
For cookie persistence you should always enable OneConnect on the virtual server. If you’re using SNAT on the serverside, you can use the default OneConnect profile with a /0 source mask. With no SNAT you should create a custom /32 source mask.
