Hi All,
I have to implement an In-Line LC ( with Two ISPs). can anyone have the quick setup configuration for the version 11.X I already googled it, but the setup implies for only V 10.X
Is there a significant difference between them, or i can simply use it.
Thank you
BR Ammar
It is almost the same between v10 and v11. LC objects are the same. Of course, the GUI and the CLI are different.
But LC is simple to understand. You have to create the links with the right monitors and create the VS in the right networks. If you need Reverse Proxy as well, you can add DNS entries.
HTH Matt
Thank you Matt, The Outgoing scenario is: Users under Different VLANs → BlueCoat → FW (Nated) → F5-LC
My approach is that i want to prefer fome users( under one VLAN) to go with ISP-2( for an example). I already told the BlueCoat Eng to insert the X-Forwarding in the header. the question is can i make a strait forward VS for these users, or i have to make an iRule and insert it under the same outgoing VS?
Thank you again.
BR Ammar
