Problem this snippet solves:
This has been edited quite a bit since I first posted so it’s probably not as quick and dirty as it was before.
This in response to a question regarding removing unused certificates https://devcentral.f5.com/questions/how-to-find-the-unused-ssl-certificates-63166
The following bash script will output any installed certificate names to a file, then iterate over each line. If the certificate is not referenced in bigip.conf in either the /config/ or within a partition folder, then it can be reasonably assumed it is not in use and can be safely deleted.
The script will give you the option to delete any certs that are not in use and save a UCS archive (just in case)
If there are any keys associated with the certificate, this will be deleted too.
As the moment, the script will not look for keys without an equivalent cert, e.g. my-cert.key and my-cert.crt. So you many still end up with rouge keys. I’ll look to get this updated eventually.
There is an array called ignoreCerts
ignoreCerts=("f5-irule.crt" "ca-bundle.crt")
Here you can add certificates you may want to ignore. For example, f5-irule.crt is used to sign F5 provided iRules and bigip.conf does not reference it.
Add any additional certs to this array to ensure they are not deleted
Script can be downloaded directly from GitLab using the link below
https://gitlab.com/stratalabs/f5-devcental/snippets/1863498/raw?inline=false
How to use this snippet:
- paste into vi
- chmod +x myScript.sh
- ./myScript.sh
Code :
#!/bin/sh
function buildInstalledCertsArray {
tmsh save sys config partitions all
tmsh list sys file ssl-cert | awk '/crt/ {print $4}' | sed '/^[[:space:]]*$/d' > /var/tmp/installedCerts.tmp
# iterate over tmp file to create array of used certificates
while read line; do
for i in "${!ignoreCerts[@]}"; do
if [[ $line = ${ignoreCerts[$i]} ]]; then
ignore="true"
else
if [[ $ignore != "true" ]];then
ignore=""
else
# do not add cert to array if already added
if [[ ! " ${instCertsArr[@]} " =~ " ${line} " ]]; then
instCertsArr+=("$line")
fi
fi
fi
done
done /dev/null 2>&1)
if ! [ -z "$hasKey" ];then
deleteKeys+=("${cert%.*}.key")
fi
done
function deleteUnusedCerts {
if [ ${#deleteCerts[@]} -eq 0 ]; then
echo "-------------------------------------------------------------------------"
echo "There are no unused certificates to delete, existing"
exit 0
else
echo "The following keys are not in use can can be deleted:"
for cert in "${deleteCerts[@]}"; do
echo " ${cert}"
done
read -p "would you like to delete these unused certificates? (y/n)?" answer
case ${answer:0:1} in
y|Y )
createUcsArchive
echo "deleting certs..."
delete sys file ssl-key $cert
echo " $cert"
done
if [ ${#deleteKeys[@]} -eq 0 ]; then
echo "no associated keys to delete, exiting"
exit 0
else
echo "deleting keys..."
for key in "${deleteKeys[@]}"; do
echo "$key"
exit 0
done
fi
exit 0
esac
fi
function createUcsArchive {
echo
today=`date +%Y-%m-%d.%H.%M.%S`
echo "Creating UCS archive auto.${today}.ucs"
tmsh save sys ucs ${today}.ucs
# initialise vars
instCertsArr=()
deleteCerts=()
# ignore certs defined here - f5-irile.crt is used to sign F5 iRules
# build installed certificates array - excluding certs to ignore
# check if installed certs are used in bigip.conf (including partitions) - ltm sys files are exluded from results
buildDeleteCertsArray
# build list of associated keys (not all certs will have keys)
buildDeleteKeysArray
# optionally delete unused certs
deleteUnusedCerts
Tested this on version:
No Version Found
