Are you trying to redirect if someone accesses the VIP through a bad hostname? If so, you should take a look at the [HTTP::host] value. If not, can you explain what you’re trying to do?
You’re correct about the URI logged being /fooserver/foo.
What I’m trying to do is if someone accesses the URI /fooserver/foo, on the virtual server this rule is applied to, then redirect them to a different URL.
I altered the rule to reflect the correct URI, but redirection does not occur.
log local0. “Checking URI [HTTP::uri] from [IP::client_addr] for insecure calls to some server”
if { [string tolower [HTTP::uri]] equals “/fooserver/foo”} {
Can you post the log output from your log statements? Your code looks correct so without knowing the exact contents of the HTTP::uri value it’s hard to guess at what is going wrong.
So is the second log statement not being reached? Since you only included the first log statement in your response I’m assuming the one in the enclosed if statement is not being reached. Is that a correct assumption. I have no clue on why a simple string comparison would not work.
I would recommend using log statements in all logic paths.
log local0. "Checking URI '[HTTP::uri]' from [IP::client_addr] for insecure calls to some server"
if { [string tolower [HTTP::uri]] equals "/fooserver/foo"} {
log local0. "Request for '[HTTP::uri]' from [IP::client_addr] is being sent to the other site"
HTTP::redirect "https://redirect.somedomain.net"
log local0. "Request for '[HTTP::uri]' from [IP::client_addr] is being allowed"
An alternate approach you could try would be something like this:
switch [string tolower [HTTP::uri]] {
"/fooserver/foo" {
default {
The only thing I can think of if the equals operator isn’t succeeding is that the original string has a space in it or something to make the equals not succeed. That’s why I’ve included quotes in the log statement to help rule that out.
If it is actually getting to the HTTP::redirect command and that isn’t in fact issuing a redirect to the client, then that’s a product issue that you’ll have to take up with product support.
Run one of these rules through and pass along the full log output and well see where we stand.
