question on WA 9.4.2 standalone
Hi WA experts,
need to find out few things regarding WA 9.4.2 standalone.
1. if i would like to deploy WA standalone in one arm, do i need to enable snatautomap in WA 9.4.2?
2. we can specify more then 1 destination host member in WA and WA will load balance connection all the server. what type of LB method and persistence method WA using?
3. where can I configure the persistence timeout value?
1. Yes you need to enable snatautomap or a snat pool.
2. You can do this, but don’t. Use the pool capabilities of the LTM portion of the stand alone WA.
3. Do this in the LTM portion of the stand alone WA.
