Is the “F5-ADD-BIG-GTM” represents the BIG-IP Add-on: Global Traffic Manager License?
Can this add-on be added to the BIG-IP LTM product F5-BIG-LTM-1600-4G-R?
Thanks.
Thanks.
I’m not sure if you can add GTM to a 1600, but it really just depends on disk space and memory availability. GTM is not that much of a resource hog. It would be easy enough to test by getting an eval license to see if you can provision it (ask your SE for one). 1600’s are End of sale though. I’m not sure it’s an available SKU for purchase.
Hi R Marc, Thanks for your reply. Lawrence Chow
