Question concerning migration with vCMP
Hello Everybody,
I have a question concerning the activation of vCMP.
When I will activate the vCMP option on my LTM, where the initial configuration will be installed (on the vCMP host?)
Thank you for your help.
Best regards,
Matthieu
Are you using Viprion Chassis?
Have a read the vCMP doument to get the understanding. vCMP is not something configurable in LTM. In simple words, it is the virtual appliances configured in the F5 hardware.
