Question about irules and Virtual servers and caching of irules
Hi
I was doing some work on an irule, i made the change and saved it. some times it comes up straight away other times the old once is cached.
How do I force the F5 / Virtual server to flush old cached irule resource and use the latest
Can you check if after you delete your connection the issue is still there? Changing an irule will only affect new connections and the old ones will use the old irule:
