Hello Team,
Iam currently working on a new build project for a customer where in they are using Viprion box for loadbalancing the traffic. We are using only two slots as of now. I have the config guide for my reference. But for preparing the initial build, i would like to see on how the CLI config would like . Could some one post me the base config and bigip.conf sample output through CLI so that i can refer and build the initial document. Thanks !!
Regards,
Karthik
I’m not sure I follow what you’re looking for. Are you looking for a complete dump of the base config files so you know what to look for? What are you looking to learn from the files? Perhaps there is a more specific question we can help answer.
Also…what version are you talking about?
Colin
Hello Colin,
You are correct. I would like to get a complete dump of the base config files so that I can check on how the syntax looks like. Just for the management purpose,Im trying to build a template with a sample CLI config of the base config so that once i get access to thebox, i can do the things through GUI. This is version 10. Thanks !!
