Is there a method for inspecting and/or modifying the contents of a cookie used to maintain persistence using an irule?
kckirwan
kckirwan
Hi kckirwan,
You can use HTTP::cookie (Click here) to retrieve and/or modify cookies in HTTP requests and/or responses. For details on the cookie used for persistence, check this codeshare example:
Persistence Cookie Logger:
http://devcentral.f5.com/wiki/default.aspx/iRules/Persistence\_Cookie\_Logger.html
Aaron
Aaron,
Thanks for the reply. I’m headed to the provided links now.
Appreciate the info,
kckirwan
