I have below questions regarding the route domain and partitions concepts.
1) Can we use the same RD in a multipal partitions. 2) We have created the single partition with two RD’s in between some these some application needs to communicate with other RD but some doesn’t need any communication, if suppose we have enabled the communication between two RD’s then will it affect the applications which doesn’t require any communication with other RD’s application 3) Can we use the same VLAN in multipal Partitions. 4) Can we use the same VLAN in multipal RD’s
I am not able to understand what you are trying to say
i feel administrative partition and route domain are different things. partition is like view of configuration but route domain is to have multiple routing table.
