qkview weird error
Hi
I generate qkview from GUI in version 10.2.1 and when copy from big-ip to client it corrupt
in corrupt qkview file it contain message
Major application error during download. See log file.
then i look at ltm log , it contain
Sep 7 15:11:43 local/F5App1 notice mcpd[3113]: 01070410:5: Removed subscription with subscriber id qkview
Sep 7 15:11:49 local/F5App1 notice logger: sh -c bigstart list 2>>/tmp/qkview_cmd.err ==> /usr/bin/bigstart list
what happen ? Does qkview error while i was copy from big-ip to client or when i generate ? and how to fix it?
Does I must run qkview from command line (tmsh)?
thank you
Is the qkview on bigip corrupt?
H
Is the qkview output on bigip corrupt? or only after the download?
H
I think I just ran into something similar. I believe this error happens when the QKview script runs into a problem, whether a file it was looking for doesn’t exist or it is truncated for whatever reason (too large). I see that in alot of the QKviews I upload. I wouldn’t consider it an indication of a problem.
How do you know the QKview is corrupt?
You can upload and analyze them with iHealth.
If they are corrupt they won’t work.
If they are good it will give you an indication of the overall “Health” of your Device and its config with suggestions on what you can do with any issues it finds.
i’m very sorry. I’m careless so when i look at size of qkview … it has 1 KB !!
so i look at file qkview when i run on big-ip it has 9 MB … so i think it error when i download from big-ip to my computer
thank you for your attention
