Python data class values
I have some python code (bigsuds) I use to display data class members names but do not know how to display the data group values. What I would like is to output the following
name value
name value
name value
Any help would be appreciated.
def member_list(b,name):
  try:
    data = b.get_string_class([name])
  except Exception, e:
    print e
  for x in data:
    myclass = x
  print name
  for m in myclass['members']:
     print m
b = f5.LocalLB.Class
member_list(b,'classname')
Hi Kevin,
I’m not sure how to accomplish this with bigsuds but here’s the solution with the Python SDK.
from f5.bigip import ManagementRoot
import urllib3
import requests
from requests.packages.urllib3.exceptions import InsecureRequestWarning
requests.packages.urllib3.disable_warnings(InsecureRequestWarning)
mgmt = ManagementRoot('192.168.1.1', 'admin', 'admin')
dgrp = mgmt.tm.ltm.data_group.internals.get_collection()
for datagroup in dgrp:
    print(datagroup.name)
    for record in datagroup.records:
        print(record)
Hi Kevin,
import urllib3
import requests
        print(record)
Joel can you provide an example of retrieving the data group values. I am trying data = bigip.ltm.data_group.internal.load(name=‘k2test’,partition=‘Common’) and its failing
Hi Kevin,
The exemple above displays all the datagroups and their values. If you want a specific datagroup to display here`s how I was able to achieve it
import urllib3
import requests
    if (datagroup.name=='aol'):
        print(datagroup.records)
Here`s an exemple of the output:
aol
[{'name': '64.12.96.0/19', 'data': ''}, {'name': '195.93.16.0/20', 'data': ''}, {'name':
'195.93.48.0/22', 'data': ''}, {'name': '195.93.64.0/19', 'data': ''}, {'name':
'195.93.96.0/19', 'data': ''}, {'name': '198.81.0.0/22', 'data': ''}, {'name': '198.81.8.0/23',
'data': ''}, {'name': '198.81.16.0/20', 'data': ''}, {'name': '202.67.65.128/25', 'data': ''},
{'name': '205.188.112.0/20', 'data': ''}, {'name': '205.188.146.144/30', 'data': ''}, {'name':
'205.188.192.0/20', 'data': ''}, {'name': '205.188.208.0/23', 'data': ''}, {'name':
'207.200.112.0/21', 'data': ''}]
Hi Kevin,
import urllib3
import requests
aol
Thanks Joel, I did figure it out in the end. The naming convention is a little strange.
data = bigip.ltm.data_group.internals.internal.load(name=‘k2test’,partition=‘Common’)
