Python Bigsuds - Massive iRule removal - bigsuds script for massive iRule removal
I am testing this python script to be able to do a mass irule removal.
It appears there is an issue with
except Exception, e:
SyntaxError: invalid syntax
Here is the snip of that lines before and after
I have not done anything to the orginal script except to line up the tab’s and indent’s.
Here is where this script lives.
Line 51 on that page would be the line that give the error.
I see on various websites this syntax was an issue pre 2.6 but i am running
Python 2.7.3 (default, Apr 10 2012, 23:24:47) [MSC v.1500 64 bit (AMD64)]
for id_rule in rules:
if rule["rule_name"] == rule_to_remove:
    try:
        b.LocalLB.VirtualServer.remove_rule([virtualservers[count]], [[rule]])
  print "\nRemove rule: %s, from vs: %s" % (rule, [virtualservers[count]])
    print e
 break
        count +=1
Any help would be greatly appreciated as this is my first time using python.
Thanks,
ccna55
It appears there is an issue with indentation. Does this snippet in your example have the same indentation as the file as it appears on your 2.7.3 system?
The parts to ‘try’ should be indented equally:
for
  if
    try:
       b.LocalLB
       print
       print e
       break
  count...   if that's where it belongs with your logic
Thanks very much for this info, With this i was able to fix the script.
Much Appreciated.
ccna55
