Problem this snippet solves:
Connects to the active member of a Device Group regardless of the original hostname. Can be used as a function or as a command-line call.
How to use this snippet:
bigip-active.py <hostname> <username>
Script will prompt for password.
Code :
#!/usr/bin/env python
# bigip_active: Connects to the active member of a Device Group regardless of
# the original hostname.
__author__ = 'buzzsurfr'
__version__ = '0.1'
# Standard Library
import sys
import itertools
# Related Third-Party
import getpass
# Local Application/Library Specific
import bigsuds
def bigip_active(hostname, username='admin', password='admin', debug=False, cachedir=None, verify=False, timeout=90):
# Connect to specified BIG-IP
b = bigsuds.BIGIP(hostname, username, password, debug, cachedir, verify, timeout)
# Determine whether device is active
if(b.Management.DeviceGroup.get_failover_status()['status'] != 'ACTIVE'):
local_device = b.Management.Device.get_local_device()
new_device = False
for device in list(set(itertools.chain.from_iterable(b.Management.DeviceGroup.get_device(b.Management.DeviceGroup.get_list())))).remove(local_device):
if(b.Management.Device.get_failover_state(device) == 'HA_STATE_ACTIVE'):
new_device = device
if(new_device):
print b.Management.Device.get_local_device()[8:]+" is not active. Switching to "+new_device[8:]
b = bigsuds.BIGIP(new_device[8:], username, password, debug, cachedir, verify, timeout)
return b
if __name__ == '__main__':
bigip_active(sys.argv[1], sys.argv[2], getpass.getpass())
Tested this on version:
11.5
