Python/Bigsuds: change_my_password does not work for guest user
I’d like to change the password of a user with guest permissions on a BIG-IP v10.2.4 using python with bigsuds. Although the login is successful (I can get a list of pools etc.), Management.UserManagement.change_my_password exits with an error:
ServerError: Server raised fault: 'Exception caught in Management::urn:iControl:Management/UserManagement::change_my_password()
Exception: Common::OperationFailed
        primary_error_code   : 17238053 (0x01070825)
        secondary_error_code : 0
        error_string         : 01070825:3: Access denied - Administrators only: User (guestuser) is not an Administrator and must supply the old password.'
How can I either supply the old password or change my password any other way?
Thanks in advance
Lukas
The problem exists in v11.4.0, too.
it doesn’t look like from the methods descriptions that a guest can change their own password in iControl. Non-guest accounts are working fine with that method to change the password. It is possible to change guest accounts on their behalf without the old password:
b.Management.UserManagement.change_password_2(['guest1'],[{'is_encrypted': 0, 'password': 'letmein99'}])
