I was able to add Internet network connectivity to the box and got pycontrol installed but still having a slight problem. I have installed suds.
[n7netutil01 python-suds-0.4]$ python2.7
Python 2.7.1 (r271:86832, Apr 5 2011, 13:47:31)
[GCC 4.1.2 20080704 (Red Hat 4.1.2-48)] on linux2
Type “help”, “copyright”, “credits” or “license” for more information.
>>> import suds
>>> print suds.__version__
0.4
>>> print suds.__build__
GA R699-20100913
Then I go to install pycontrol.
[n7netutil01 trunk]$ sudo python2.7 setup.py install
running install
running bdist_egg
running egg_info
writing requirements to pycontrol.egg-info/requires.txt
writing pycontrol.egg-info/PKG-INFO
writing top-level names to pycontrol.egg-info/top_level.txt
writing dependency_links to pycontrol.egg-info/dependency_links.txt
writing manifest file ‘pycontrol.egg-info/SOURCES.txt’
installing library code to build/bdist.linux-x86_64/egg
running install_lib
running build_py
creating build/bdist.linux-x86_64/egg
creating build/bdist.linux-x86_64/egg/pycontrol
copying build/lib/pycontrol/setup.py → build/bdist.linux-x86_64/egg/pycontrol
copying build/lib/pycontrol/__init__.py → build/bdist.linux-x86_64/egg/pycontrol
copying build/lib/pycontrol/pycontrol.py → build/bdist.linux-x86_64/egg/pycontrol
copying build/lib/pycontrol/utils.py → build/bdist.linux-x86_64/egg/pycontrol
byte-compiling build/bdist.linux-x86_64/egg/pycontrol/setup.py to setup.pyc
byte-compiling build/bdist.linux-x86_64/egg/pycontrol/__init__.py to __init__.pyc
byte-compiling build/bdist.linux-x86_64/egg/pycontrol/pycontrol.py to pycontrol.pyc
byte-compiling build/bdist.linux-x86_64/egg/pycontrol/utils.py to utils.pyc
creating build/bdist.linux-x86_64/egg/EGG-INFO
copying pycontrol.egg-info/PKG-INFO → build/bdist.linux-x86_64/egg/EGG-INFO
copying pycontrol.egg-info/SOURCES.txt → build/bdist.linux-x86_64/egg/EGG-INFO
copying pycontrol.egg-info/dependency_links.txt → build/bdist.linux-x86_64/egg/EGG-INFO
copying pycontrol.egg-info/requires.txt → build/bdist.linux-x86_64/egg/EGG-INFO
copying pycontrol.egg-info/top_level.txt → build/bdist.linux-x86_64/egg/EGG-INFO
zip_safe flag not set; analyzing archive contents…
creating ‘dist/pycontrol-2.0.1a-py2.7.egg’ and adding ‘build/bdist.linux-x86_64/egg’ to it
removing ‘build/bdist.linux-x86_64/egg’ (and everything under it)
Processing pycontrol-2.0.1a-py2.7.egg
Removing /opt/python2.7.1/lib/python2.7/site-packages/pycontrol-2.0.1a-py2.7.egg
Copying pycontrol-2.0.1a-py2.7.egg to /opt/python2.7.1/lib/python2.7/site-packages
pycontrol 2.0.1a is already the active version in easy-install.pth
Installed /opt/python2.7.1/lib/python2.7/site-packages/pycontrol-2.0.1a-py2.7.egg
Processing dependencies for pycontrol==2.0.1a
Searching for suds==0.4
Best match: suds 0.4
Processing suds-0.4-py2.7.egg
suds 0.4 is already the active version in easy-install.pth
Using /opt/python2.7.1/lib/python2.7/site-packages/suds-0.4-py2.7.egg
Finished processing dependencies for pycontrol==2.0.1a
That looks like it installed fine. But then once I enter python it 's acts like suds is not installed.
[n7netutil01 trunk]$ python2.7
>>> import suds
Traceback (most recent call last):
File “”, line 1, in
ImportError: No module named suds
>>> import pycontrol.pycontrol as pc
File “”, line 1, in
File “pycontrol/__init__.py”, line 32, in
import suds
Thanks for the other response.
