Hello All,
I am trying to write a pycontrol statement that will enable/disable a pool member in a gtm pool.
I’m getting stuck on the MemberEnabledState parameter that i need to pass. I’ve tried so far:
import pycontrol.pycontrol as pc
memberEnabledState = {}
memberEnabledState[‘member’] = (Common.IPPortDefinition){
address = “167.69.74.38”
port = 443
memberEnabledState[‘state’] = ‘STATE_ENABLED’
pc.BIGIP(hostname=gtm,username=soapUser,password=soapPasswd,fromurl=True,wsdls=content).GlobalLB.Pool.set_enabled_state([gtm_pool],memberEnabledState)
Thanks in advanced,
Jim
I reworked my memberEnabledState obj:
>>> memberEnabledState
(GlobalLB.PoolMember.MemberEnabledState){
member =
address = “167.69.x.x”
port = “443”
state =
(Common.EnabledState){
value = 1
so now it is correctly defined
however when I try to run it..
gtmPoolMemberObj = b.BIGIP(hostname=host,username=user,password=pass,fromurl=True,wsdls=[‘GlobalLB.PoolMember’])
gtmPoolMemberObj.GlobalLB.PoolMember.set_enabled_state([gtm_pool], memberEnabledState)
I get:
suds.TypeNotFound: Type not found: ‘member’
The memberEnabledState argument is a sequence sequence.
should be something like
gtmPoolMemberObj.GlobalLB.PoolMember.set_enabled_state([gtm_pool], [[memberEnabledState]])
I’m not a pycontrol user so I’m guessing at the actual syntax.
Mark
returns..
suds.WebFault: Server raised fault: ‘Could not find element by name: member’
Found answer here. DevCentral
Had to put memberEnabledState into a F5 MemberEnabledStateSequence obj!
BAM!
