Pull info from SSL Client Cert
I need an irule to pass on Client Cert information from a HTTPS request to the backend pool
Attributes I’d like sent along in HTTPS headers:
Certificate status - The status of the client certificate. The value of [status] can be NoClientCert, OK, or Error. If status is NoClientCert, only this header is inserted into the request. If status is Error, the error is followed by a numeric error code.
Certificate serial number
Issuer of the certificate
Certificate subject (Distinguished name or DN)
Thanks to anyone that can help me out.
To do so you’ll need the BIGIP to be the SSL termination of the the HTTPS flow.
Then you can use those commands to do the kjob :
Certificate serial number: Click here
Certificate issuer: Click here
Certificate subject: Click here
An example of certificate manipulation can be found here: Click here
to insert HTTP header it is simple: Click here
Here is an example of code to work from:
when HTTP_REQUEST
  set pkiSubject [X509::subject $the_cert]
  set pkiIssuer [X509::issuer $the_cert]
  HTTP::header insert CN $pkiSubject
  HTTP::header insert SSLIssuer $pkiIssuer
  HTTP::header insert SSLClientCertSN [regsub -all {:} [X509::serial_number $the_cert] -]
