Im using F5 BIGIP v13 as reverse proxy to publish some websites. When publishing using SSL with a 3rd party certificate it works. But now im trying to publish an internal site with a certificate signed with my local CA, and no way to make it work.
I have created two VS. One for HTTP and another for HTTPS. Publishing the site as HTTP works: client --http--> F5 --http--> server
Publishing the same site as HTTPS, does not work: client --https--> F5 --https--> server
The server responds correctly to both HTTP and HTTPS.
The certificate with the full chain (the internal CA root cert) is imported. The VS is configured with a client ssl profile with the certficate, key and chain. The VS is configured with the default serverssl profile.
Firefox shows an error: “The page you are trying to view cannot be shown because the authenticity of the received data could not be verified.”
CONNECTED(00000003)depth=1 DC = lan, DC = mydomain, CN = myou verify error:num=19:self signed certificate in certificate chainverify return:0…No client certificate CA names sent…Verify return code: 19 (self signed certificate in certificate chain)
Am I doing something wrong? What would be the correct way to configure this?
I would also recommend you to check the certificate is imported on the backend real server since you are using serverssl profile to re-encrypt the traffic to real server.
I havent explained correctly, but the correct connection flow would be:
Client --> F5 (VS Rev.Proxy) --> F5 (VS Balanced Web Servers) --> Web Server nodes
I think the problem is not at the serverssl profile level because i cannot see any packet using tcpdump destinated to the second VS (the balancing one) when causing the problem in the browser. Anyway tried the serverssl profile insecure-compatible but no success.
Yeah! That was the problem. Sorry, forgot to mention the connection to the second virtual server.
But, what is behind the virtual server there are several published sites with multiple certificates? What would be the correct way to configure the SSL in the virtual server?
