Public vs Private Virtual IP
Guys,
What is the difference with assigning a private or a public Virtual IP.
Thanks in advance!
The only significant difference would be “routability”. The generally established private IP subnets are defined here:
as:
10.0.0.0/8
 172.16.0.0/12
 192.168.0.0/16
and are basically ranges of addresses that are considered private and will not route across the Internet. They can route internally in your environment though. So I suppose to more specifically answer your question, a private address is any address in one of the above ranges that you might apply to a VIP that either is not directly connected to the Internet and/or is used for internal testing/development. An external IP address is anything not in the above ranges and would be directly accessible across the Internet. There is otherwise no functional difference between the two as far as a virtual server is concerned.
Choosing between Private and Public IPs for Virtual Servers has other ramifications as well. Example: If your are using the GTM module, using Private IP addressess and specifying translation on your vips will hinder Virtual Discovery from working:
sol9138: The BIG-IP GTM system disables virtual server auto-discovery for BIG-IP systems that use translated virtual server addresses 404 Page not found | BIG-IP Documentation
Thanks Nathan for this.
