Problem this snippet solves:
This sample is the beginning of a full console-based management environment for your BIG-IP. Written in PowerShell, you are able to treat your BIG-IP just like your file system and navigate through, and act on, the objects in the system.
Revision History
1.0.0 - First revision. Includes initial code for gtm.wideip, ltm.pool/poolmember/virtualserver, networking.vlan, and system.systeminfo.
How to use this snippet:
Setup And Running The Script
Save the iControlsh.ps1 file to a directory on your system.
Save the various modules to the following directory structure.
installdir\iControlsh.ps1 installdir\modules\gtm\wideip.ps1 installdir\modules\ltm\pool.ps1 installdir\modules\ltm\poolmember.ps1 installdir\modules\ltm\virtualserver.ps1 installdir\modules\networking\vlan.ps1 installdir\modules\system\systeminfops1 -
Run the script
installdir> .\iControlsh.ps1 -
Connect to your BIG-IP
PLEASE CONNECT> : c bigip user pass bigip> : -
Navigate through the objects and issue some commands. At any level, type “h” for help.
Files
iControlsh.ps1
Code :
# The contents of this file are subject to the "END USER LICENSE AGREEMENT
# FOR F5 Software Development Kit for iControl"; you may not use this file
# except in compliance with the License. The License is included in the
# iControl Software Development Kit.
# Software distributed under the License is distributed on an "AS IS"
# basis, WITHOUT WARRANTY OF ANY KIND, either express or implied. See
# the License for the specific language governing rights and limitations
# under the License.
# The Original Code is iControl Code and related documentation
# distributed by F5.
# The Initial Developer of the Original Code is F5 Networks,
# Inc. Seattle, WA, USA. Portions created by F5 are Copyright (C) 1996-2010
# F5 Networks, Inc. All Rights Reserved. iControl (TM) is a registered
# trademark of F5 Networks, Inc.
# Alternatively, the contents of this file may be used under the terms
# of the GNU General Public License (the "GPL"), in which case the
# provisions of GPL are applicable instead of those above. If you wish
# to allow use of your version of this file only under the terms of the
# GPL and not to allow others to use your version of this file under the
# License, indicate your decision by deleting the provisions above and
# replace them with the notice and other provisions required by the GPL.
# If you do not delete the provisions above, a recipient may use your
# version of this file under either the License or the GPL.
param([switch]$Debug = $false);
# Global Script variables
$script:VERSION = "1.0.0";
$script:ICONTROLSH = $true;
$script:DEBUG = $Debug;
$script:BIGIP = "";
$script:Username = "";
$script:Password = "";
$script:Connected = $false;
# Current path
$script:HOSTNAME = "";
$script:CURPATH = "PLEASE CONNECT";
# Path Hashtable
$script:PATHS = @{};
function Debug-Message()
param($msg);
if ( $script:DEBUG )
Write-Host "[DEBUG] $msg";
function Initialize-Connection()
param($line = $null);
if ( $line )
$tokens = $line.Split(" ");
Load-Configuration;
if ($tokens.length -eq 4 )
$script:BIGIP = $tokens[1];
$script:Username = $tokens[2];
$script:Password = $tokens[3];
if ( ($script:BIGIP.Length -gt 0) -and
($script:Username.Length -gt 0) -and
($script:Password.Length -gt 0) )
if ( (Get-PSSnapin | Where-Object { $_.Name -eq "iControlSnapIn"}) -eq $null )
Add-PSSnapIn iControlSnapIn
$script:Connected = Initialize-F5.iControl `
-HostName $script:BIGIP -Username $script:Username -Password $script:Password;
if ( $script:Connected )
$sysInfo = (Get-F5.iControl).SystemSystemInfo.get_system_information();
$script:CURPATH = $sysInfo.host_name;
$script:HOSTNAME = $sysInfo.host_name;
function Exit-Console()
Save-Configuration;
exit;
function Validate-RegistryKey()
param($Name = $null);
$keyroot = "HKCU:\Software";
if ( $Null -ne $name )
$key = Get-Item "${keyroot}\$Name" -ErrorAction silentlyContinue;
if ( $null -eq $key ) { New-Item -Path "${keyroot}\$Name"; }
function Load-Configuration()
$hive = Get-ItemProperty -Path "HKCU:\Software\F5 Networks\iControlsh" `
-Name "BIGIP" -ErrorAction SilentlyContinue;
if ( $null -ne $hive ) { $script:BIGIP = $hive.BIGIP; }
-Name "Username" -ErrorAction SilentlyContinue;
if ( $null -ne $hive ) { $script:Username = $hive.Username; }
-Name "Password" -ErrorAction SilentlyContinue;
if ( $null -ne $hive ) { $script:Password = $hive.Password; }
function Save-Configuration()
Validate-Registrykey "F5 Networks";
Validate-RegistryKey "F5 Networks\iControlsh";
if ( $script:BIGIP.Length -gt 0 )
Set-ItemProperty -Path "HKCU:\Software\F5 Networks\iControlsh" `
-Name "BIGIP" -Value $script:BIGIP;
if ( $script:Username.Length -gt 0 )
-Name "Username" -Value $script:Username;
if ( $script:Password.Length -gt 0 )
-Name "Password" -Value $script:Password;
function Get-CurrentPath()
return $script:CURPATH;
function Set-CurrentPath()
param($path);
$script:CURPATH = $path;
function Add-ScriptPath()
param($key, $value);
Debug-Message "< $($MyInvocation.MyCommand.Name) >";
Debug-Message "Key = '$key'; Value = '$value'";
$v = $script:PATHS[$key];
if ( $null -eq $v )
Debug-Message "null -eq '$v'"
$script:PATHS.Add($key, $value);
else
Debug-Message "null -ne $v"
$v2 = "$v,$value";
Debug-Message "Adding $key = '$v2'";
$script:PATHS[$key] = $v2;
$v3 = $script:PATHS[$key];
Debug-Message "$key = '$v3'";
function Show-Help()
param([switch]$Full, $Topic = $null);
$indent = " "*10;
if ( $Topic -and ($Topic.Length -gt 0) )
$key = (Get-CurrentPath).Replace($script:HOSTNAME, "icsh");
$key += "/" + $Topic;
Get-Help -Full $key;
else
if ( $Full )
Write-Host @"
$indent ================================================================
$indent iControl Interactive Console Help
$indent Global Commands
$indent ---------------
$indent c - connect to LTM with args "bigip user pass"
$indent h - print this help message.
$indent i - show connection information.
$indent q - exit the console.
$indent r - reload the modules.
Write-Host @"
$indent .. - Move up one level.
$indent cmd - level specific command and arguments
Write-Host @"
$indent Child Objects
$indent ----------------
$entry = (Get-HashEntry $script:PATHS)
if ( $null -ne $entry )
$children = $entry.Split(',');
foreach($child in $children)
Write-Host "$indent $child";
Write-Host @"
$indent Commands In this object
$indent -----------------------
$validCmds = Get-ValidCommands;
foreach($cmd in $validCmds)
Write-Host "$indent $cmd";
function Show-Information()
Write-Host @"
Shell Version : $($script:VERSION)
Connected State : $($script:Connected)
BIGIP : $($script:BIGIP)
Username : $($script:Username)
Password : $($script:Password)
Debug : $($script:DEBUG)
function Move-Up()
#$tokens = (Get-CurrentPath).Split(":");
$tokens = (Get-CurrentPath).Split("/");
if ($tokens.Length -gt 1)
$newpath = "";
for($i=0; $i -lt $tokens.Length-1; $i++)
#if ( $i -gt 0 ) { $newpath += ":"; }
if ( $i -gt 0 ) { $newpath += "/"; }
$newpath += $tokens[$i];
if ( $newpath.Length -gt 0 )
Set-CurrentPath $newpath;
function Move-Down()
param($subdir);
$newpath = Get-CurrentPath;
#$newpath += ":";
$newpath += "/";
$newpath += $subdir;
#Show-Help;
function Get-HashEntry()
param($hash, $key=(Get-CurrentPath));
$key = $key.Replace($script:HOSTNAME, "icsh");
Debug-Message "< $($MyInvocation.MyCommand.Name) '$key' >";
return $hash[$key];
function Find-HashEntry()
param($cmd, $hash);
Debug-Message "< $($MyInvocation.MyCommand.Name) '$cmd' >";
$valid = $false;
$entry = (Get-HashEntry $hash)
if ( $child -eq $cmd )
$valid = $true;
break;
return $valid;
function Is-SubDirectory()
param($cmd);
return Find-HashEntry $cmd $script:PATHS;
function Get-ValidCommands()
$path = (Get-CurrentPath)
$cmdPrefix = $path.Replace("$($script:HOSTNAME)", "icsh") + "/";
Debug-Message "Getting valid commands from CmdPrefix: '$cmdPrefix'";
$validCmds = Get-Command -CommandType Function "${cmdPrefix}*" |
Foreach-Object -Process { $_.Name.Replace($cmdPrefix, "") }
$validCmds;
function Is-ValidCommand()
param($cmd);
$bValid = $false;
$tokens = $cmd.Split(" ");
Debug-Message "Valid Commands";
Debug-Message $validCmds;
foreach($validCmd in $validCmds)
if ( $validCmd -eq $tokens[0] )
Debug-Message "Command '$($tokens[0])' matched '$validCmd'";
$bValid = $true;
break;
return $bValid;
function Gen-FunctionName()
param($cmd);
if ( $cmd )
$path = Get-CurrentPath;
$function = "icsh/";
#$tokens = $path.Split(":");
$tokens = $path.Split("/");
for($i=1; $i -lt $tokens.length; $i++)
if ( $i -gt 1 ) { $function += "/"; }
$function += $tokens[$i];
if ( $function -ne "icsh/" ) { $function += "/"; }
$function += $cmd;
Debug-Message "Returning function '$function'";
return $function;
function Process-Command()
param($cmd);
$command = $tokens[0];
$args = "";
for($i=1; $i-lt$tokens.Length; $i++)
if ( $i -gt 1 ) { $args += " "; }
$args += $tokens[$i];
$key = $(Get-CurrentPath) + "/" + $command;
$code = Gen-FunctionName $command;
Debug-Message "Processing command: '$code' '$args'";
if ( $args.Length -gt 0 ) { $code += " -Opts '$args'"; }
Debug-Message "Invoking code <$code>";
Invoke-Expression $code;
function Get-CommandName()
param($line);
$cmd = $line.Trim();
$idx = $cmd.IndexOf(' ');
if ( -1 -ne $idx )
$cmd = $cmd.SubString(0, $idx).Trim();
return $cmd;
Function Get-Arguments()
param($line);
$args = "";
$idx = $line.Trim().IndexOf(' ');
if ( -1 -ne $idx )
$args = $line.SubString($idx+1).Trim();
return $args;
function Convert-To64Bit()
param($high, $low);
return ($high*[Math]::Pow(2,32))+$low;
# Main script logic
$curdir = $MyInvocation.MyCommand.Path.Replace($MyInvocation.MyCommand.Name, "");
$LoadModStr = @"
`$script:PATHS.Clear();
# Iterate through all the modules
`$modules = Get-ChildItem `$curdir\Modules\* |
Where-Object { `$_.GetType().Name -eq "DirectoryInfo" }
foreach(`$module in `$modules)
`$mod = `$module.BaseName.ToLower();
Add-ScriptPath "icsh" `$mod;
# iterate through the interfaces
`$files = Get-ChildItem `$curdir\Modules\`$mod\* |
Where-Object { `$_.GetType().Name -eq "FileInfo" }
foreach(`$file in `$files)
Add-ScriptPath "icsh/`$mod" `$file.BaseName.ToLower();
Debug-Message "Invoking content for script `$(`$file.FullName)";
. `$file.FullName;
Invoke-Expression $LoadModStr;
while(1)
$prompt = "$(Get-CurrentPath)> ";
$i = (Read-Host $prompt).Trim();
Debug-Message "< $($MyInvocation.MyCommand.Name) '$i' >";
if ( $i.Length -gt 0 )
Debug-Message "CommandLine: '$i'...";
switch -Wildcard ($i.ToLower())
"" { break; }
"c*" { Initialize-Connection $i; }
"h*" { Show-Help -Full -Topic (Get-Arguments $i); }
"i" { Show-Information; }
"q" { Exit-Console; }
"r" { Invoke-Expression $LoadModStr; }
"d" { $script:DEBUG = -not $script:DEBUG; }
$cmd = $i.Replace("!", "").Trim();
Debug-Message "Executing command $cmd";
Invoke-Expression $cmd;
".." { Move-Up; }
default {
if ( Is-SubDirectory $i ) { Move-Down $i; }
elseif ( Is-ValidCommand $i ) { Process-Command $i; }
else { Show-Help; }
else
Show-Help;
