ok so I think I am getting closer but am getting a 404 now which is wrong. Even though it see’s /workflow it isn’t reverse proxying the request… ANy ideas?
thanks!
Dec 10 07:35:22 local/tmm3 info tmm3[22434]: Rule Proxy_Pass_Common : VS=HTTP_DEV.SUNY.EDU, Host=dev.suny.edu, URI=/workflow/: Found Rule, Client Host=dev.suny.edu, Client Path=/workflow, Server Host=scenda6.sysadmin.suny.edu:7777, Server Path=/workflow
Dec 10 07:35:22 local/tmm3 info tmm3[22434]: Rule Proxy_Pass_Common : VS=HTTP_DEV.SUNY.EDU, Host=dev.suny.edu, URI=/workflow/: Using default pool http_DEV_suny_edu
Dec 10 07:35:22 local/tmm3 info tmm3[22434]: Rule Proxy_Pass_Common : VS=HTTP_DEV.SUNY.EDU, Host=dev.suny.edu, URI=/workflow/: New Host=scenda6.sysadmin.suny.edu:7777, New Path=/workflow/
Dec 10 07:35:22 local/tmm3 info tmm3[22434]: Rule Proxy_Pass_Common : VS=HTTP_DEV.SUNY.EDU, Host=dev.suny.edu, URI=/workflow/: Removed Accept-Encoding header
Dec 10 07:35:22 local/tmm3 info tmm3[22434]: Rule Proxy_Pass_Common : VS=HTTP_DEV.SUNY.EDU, Host=dev.suny.edu, URI=/workflow/: 404 response from http_DEV_suny_edu 141.254.104.152 80
Dec 10 07:35:22 local/tmm3 info tmm3[22434]: Rule Proxy_Pass_Common : VS=HTTP_DEV.SUNY.EDU, Host=dev.suny.edu, URI=/workflow/: $stream_expression_cmd: STREAM::expression “@scenda6.sysadmin.suny.edu:7777/workflow@dev.suny.edu/workflow@”, $stream_enable_cmd: STREAM::enable
Dec 10 07:35:22 local/tmm3 info tmm3[22434]: Rule Proxy_Pass_Common : VS=HTTP_DEV.SUNY.EDU, Host=dev.suny.edu, URI=/workflow/: Successfully configured and enabled stream filter
Dec 10 07:35:22 local/tmm3 info tmm3[22434]: Rule Proxy_Pass_Common : VS=HTTP_DEV.SUNY.EDU, Host=dev.suny.edu, URI=/workflow/: Checking Location=, $protocol=
Dec 10 07:35:22 local/tmm3 info tmm3[22434]: Rule Proxy_Pass_Common : VS=HTTP_DEV.SUNY.EDU, Host=dev.suny.edu, URI=/workflow/: Checking Content-Location=, $protocol=
Dec 10 07:35:22 local/tmm3 info tmm3[22434]: Rule Proxy_Pass_Common : VS=HTTP_DEV.SUNY.EDU, Host=dev.suny.edu, URI=/workflow/: Checking URI=, $protocol=
