I’m using ProxyPass to redirect a SharePoint 2007 site “teams/it” to “teams2010/it”. It is redirecting some links, but not all of them. It seems to be related to this log entry “Rewriting response content enabled, but disabled on this response.” I’ve run out of ideas. Any help would be much appreciated!
For Sharepoint, it’s generally simpler and more efficient to use Alternate Access Mappings to create public mappings of internal hostnames/URIs. If that’s not an option, then you could use ProxyPass.
ProxyPass won’t attempt to rewrite response content for images payloads--they’re binary so there isn’t anything to rewrite. Also, that logo.gif file doesn’t match any of your config data group entries as the URI doesn’t start with /it.
Is there an example of an HTML page whose content isn’t being rewritten? If so, can you post the /var/log/ltm log snippet for that?
Thanks for the response. My challenge is redirecting a 2007 subsite to a new 2010 farm for migration purposes. I’ve updated a couple of URIs to the Data Group and have almost everything working except for the Ribbon and the Site Action Dropdown. It appears that it is not initializing properly. I haven’t fonud any errors related to this in the F5 logs.
Browser Error: Message: ‘_ribbonOnStartInit’ is undefined
The only remaining issues (using ProxyPass) are the Ribbon not loading and the following errors that appear to be related to compression. I don’t see any errors in the LTM log. What’s the best way to disable compression? Should I add another iRule for this or disable it in IIS? This configuration is being used only for mogration so it is temporary.
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; WOW64; Trident/4.0; GTB7.3; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; InfoPath.3; .NET4.0C; .NET4.0E; MS-RTC EA 2; MS-RTC LM 8)
