Proxypass functionality in f5 (11.2.1 hf13)
First time posting a question - hoping someone can help.
Objective: somehow intercept one of siteminder added headers and based on value of the header, proxypass the rest of the requests to appropriate servers.
working example: user requests abc.com/def → f5 → reverse proxy → siteminder does it thing (including adding additional headers) → apache reverse proxy sends /def to .xyz Domain Names | Join Generation XYZ → xyz is a f5 vs → f5 sends to appropriate pool member. This is repeated for other url’s, where abc.com/ghi will be serviced by 123.com/ghi
Objective example: user requests abc.com/def → f5 → reverse proxy → siteminder does it thing (including adding additional headers) → somehow inspect the additional siteminder added headers and based on the value proxy all communication to certain servers (f5 vs’s). As an example, user requests abc.com/def → f5 → reverse proxy → siteminder does it thing (including adding additional headers) → if http_header aaa = bbb then proxy /def to .xyz Domain Names | Join Generation XYZ or if http_header aaa = ccc then proxy /def to 1234.com/def, etc…
so far: Was able to capture the siteminder headers while the request was forwarded from the proxy server to f5. But unable to proxy this request. As an example, user requests abc.com/def → f5 → reverse proxy → siteminder does it thing (including adding additional headers) → apache reverse proxy sends /def to .xyz Domain Names | Join Generation XYZ → xyz is a f5 vs → able to capture the siteminder header here (shows up as part of http_request) → how to proxy it from here?
Tried Proxypass but it doesn’t work - may be i am doing something wrong?
The classes are defined much differently in 11.4 - so more or less some development needs to be made within the iRule for ProxyPass. Take a look when calling SNAT class as it is redefined.
