We are trying to implement proxy protocol (for use with RabbitMQ AMQP) and have this irule:
when CLIENT_ACCEPTED{
set proxyheader "PROXY TCP[IP::version] [IP::remote_addr] [IP::local_addr] [TCP::remote_port] [TCP::local_port]\r\n"
when SERVER_CONNECTED {
TCP::respond $proxyheader
But keep receiving a logged error:
TCL error: /Common/rabbitMQ_proxy_protocol - Operation not supported (line 1) invoked from within "TCP::respond $proxyheader"
This page below says that TCP::respond is a valid command for SERVER_CONNECTED. Any ideas?
https://devcentral.f5.com/wiki/iRules.SERVER_CONNECTED.ashx
What are you trying to accomplish?
After restarting the BIGIP we are no longer receiving the operation not supported error.
Load balance RabbitMQ cluster-it requires the proxy protocol when going through the BIGIP
Are you load-balancing AMQP?
Yes-we are using TLS1.2 on a standard virtual server port 5671. Our rabbitmq.conf has ssl.options specified as well as version TLS1.2. We have it load balancing and working now.
Awesome! We are going to upgrade our RabbitMQ server and give that a shot. We will definitely use that tls1.2 info. Appreciate it!
Cheers!
This is how we configured rabbitmq.conf to get it working:
listeners.ssl.default = 5671
proxy_protocol = true
ssl_options.cacertfile = /path/to/cacert.pem
ssl_options.certfile = /path/to/cert.pem
ssl_options.keyfile = /path/to/key.pem
ssl_options.verify = verify_peer
ssl_options.fail_if_no_peer_cert = false
ssl_options.depth = 3
ssl_options.versions.1 = tlsv1.2
auth_mechanisms.1 = PLAIN
auth_mechanisms.2 = AMQPLAIN
auth_mechanisms.3 = EXTERNAL
On the F5 appliance, create an iRule with the following contents:
when CLIENT_ACCEPTED {
when SERVER_CONNECTED {TCP::respond $proxyheader}
Is SSL offloading on the rabbitmq server or the F5?
Thanks.
