Hi all,
I’m running a web-facing (as opposed to internal) IIS / ASP application behind an HA pair of 3900’s with 10.2.3. We’d like to use the F5s to squeeze every last drop of performance from the application. I guess we all do…
One thing we’ve noted from tcpdumps on the client and server side is that about 60% of our clients perform their tcp three-way-handshake advertising a maximum segment size / MSS *other* than 1460, while *all* responses from the servers appear to come back at 1460.
I figure this means the F5 must chunk those responses down into 2 packets before sending them on to the client, e.g. if a client has an MSS of 1400 but the server responds with 1460, the F5 must be splitting that reponse from the server into 2 packets - one at 1400 and another at 60 before sending them on. The F5s are fast but surely there’s a time penalty?
We’ve modified both the client and server TCP protocol profiles to “Proxy maximum segment”, yet the tcpdumps we perform still show 1460 sized packets coming from the server.
Our production VS uses OneConnect with the IIS servers having “HTTP keep-alives”, but even on a POC VS without OneConnect and HTTP keep-alives turned on we still don’t see the proxy maximum segment setting behaving as we expect, i.e. from the example above the server does not respond with 1400 sized packets.
My question for the group - is my understanding of the setting incorrect, or do we have an issue here?
The details of the TCP profile (and it’s parents) are below:
profile tcp PROD_Profile_TCP-WAN {
defaults from tcp-wan-optimized
proxy mss enable
nagle disable profile
tcp tcp-wan-optimized {
defaults from tcp
selective acks enable
nagle enable
proxy buffer low 131072
proxy buffer high 131072
send buffer 65535
recv window 65535
profile tcp tcp {
reset on timeout enable
time wait recycle enable
delayed acks enable
proxy max segment disable
proxy options disable
deferred accept disable
ecn disable limited transmit enable
nagle enable
rfc1323 enable
slow start enable
bandwidth delay enable
ack on push disable
idle timeout 300
time wait 2000
fin wait 5
close wait 5
send buffer 32768
recv window 32768
keep alive interval 1800
max retrans syn 3
max retrans 8
congestion control highspeed
zero window timeout 20000
