Source address persistence profiles don’t work when a client traverses through a proxy. Is there some way to incorporate source address and source port in a iRule, basically to persist on the source port being used by the client?
I believe you could do this by the following examples using Universal Persistence
Both Client and source port
when CLIENT_ACCEPTED {
persist uie [concat [IP::remote_addr] [TCP::remote_port]]
or
persist uie [concat [IP::remote_addr] [UDP::remote_port]]
or
Just the source ports
persist uie [TCP::remote_port]
or
persist uie [UDP::remote_port]
Hope this helps
CB
