Protected resource custom check
Hi all,
I’m using firepass version 6.0.3
Is it possible to use an advanced session variable in a protected resource check?
I have created an advanced session variable which returns “OHRA” in some circumstances. I’ve named the advanced session variable “Test”
I’ve then created a custom check in a protected resource as follows
session.asv.Test ==“OHRA”
But it is not working…
I’ve also tried
session.asv.Test ==OHRA
%session.asv.Test% ==OHRA
%session.asv.Test% ==“OHRA”
I know that the variable is being evaluated and returns correctly because I followed a KB article and set the variable as the name of an application link - the variable is there plain as day on the screen as the name of the application link, yet when I use it in the protected resource check as above it fails the test.
Looking forward to hearing from anyone who can help with this one.
Stephan
Check the logon variables and see if it is populating. Maintenance → Troubleshooting → System variables.
