Hello,
It’s my first question here. I have routing domain in my BIGIP and nodes, pools, snat translation and virtual servers associated with route domains.
I want to move all these objects to route domain 0 and delete my 2 route domains. What is the clean way to do it ?
Thank you
clean way would be to just create everything again in route domain 0, delete the configuration in the other route domains.
if you feel secure with the config in the bigip.conf then you can edit that, remove all route domain references and do a tmsh load sys config.
i would take some measures to make sure you don’t end up with an unloadable config. make a UCS archive backup or snapshot if you run it virtually.
