I am attempting to prompt the user for the certificates he wishes to use to authenticate them self to my application. From the certificate, all that I care about is the username that is within it, ex: CN=joeBob . My plan is then: 1) User inserts CAC 2) F5 prompt for certificates prompt 3) parse certificate and grab out username 4) do some AD query with that username
I am stuck on the first part of the problem, step 2, where I cannot seem to prompt the user for a certificate. Here is how my APM policy looks like:
My virtual server is set to use a tomcat client cert and the default ssl cert for the server. (I am doing this as the client cert being presented to the user, is from the application server hosting my application. The user should still validate that they are connecting to the right place) And the default ssl cert is the one I am using to ensure traffic is encrypted between tomcat and F5.
Here is a picture of how my client profile looks like:
You can set your client ssl profile to require and add a client inspection block in the vpe. It should works fine. On-Demand Cert Auth is a particular use case where you need certificate authentication after a login page and AD auth for example.
I think it should be better to post on APM instead of iRule part.
1. The CA certificate (tomcat-cert) move from CA certificate in SSL forward proxy to “Trusted Certificate Authorities” in Client Authentication part.
2. My understanding is that “On-Demand Cert Auth” can trigger to request client side to present client certificate with initiating a new SSL session. It doesn’t matter to set “ignore” in Client Certificate field. The best way to troubleshooting for this case is to capture tcpdump for checking SSL handshake. Some of case, browser silently provide client certificate without prompt.
