Hello,
I was wondering if there is a best practice to progammatically installing SSL certificates in F5 without manual intervention. With the assumption the the certificates are generated by a third party and can be placed on any server that the certificates are needed on
My suggestion would be to investigate doing this with iControl (http://devcentral.f5.com/Community/TopicGroups/tabid/1082223/asg/51/showtab/groupforums/Default.aspx).
You could do this via CLI to place the Certificate and Key files in the proper directories, but in order to use them you would still need to place them in SSL Profiles and apply them to a Virtual Server which would require direct interface with the main bigip.conf configuration file. Any edits to that file would require a b load to to take effect and that can be disruptive to passing traffic while the configuration file is reloaded.
