Hello
Please provide me with full set of technical documents for for any BIGIP product
- 62368 CB scheme certificate & report
- EN 55032 report
- EN 55035 report
Hello
You need to lookj at the hardware documentation. Go to https://support.f5.com/csp/knowledge-center/hardware and look for the required hardware. Go to Platform Specifications, for instance https://techdocs.f5.com/en-us/hw-platforms/platform-guide-i2000i4000-series/title–platform-specifications.html#emc-reqs
Hello
I looked but no documentas I need are shown there
OK, can i suggest that you provide more information about your requirements then. Which hardware platform do you require the certificate for? Maybe you should contact F5 directly if you have specific requirements - raise a support case and be specific about exactly what you want.
These document are needed in order to import F5 product to ISRAEL. they are rquired by the custom.
I need it for the i2000/4000 and if you also for ant Rseries
Ronen
If you look at https://techdocs.f5.com/en-us/hw-platforms/platform-guide-i2000i4000-series/title–platform-specifications.html#emc-reqs
you will see EN 55032 certification:
This equipment complies with these requirements of the EMC Directive 2014/30/EU:As Telecommunication Network Equipment (TNE) in Both Telecom Centers and Other than Telecom Centers per (as applicable):
| ETSI EN 300 386 V1.6.1 (2012) |
| EN 55032:2012/AC:2013 |
| EN 61000-3-2:2014 |
| EN 61000-3-3:2013 |
As for the other requirements, create an F5 Support case and ask whether it is certified to those specifications.
@Ronenb - I’m marking this as Solved. If you disagree you may unselect the solution, select other replies as solutions, or continue the conversation as necessary. Thank you.
Lief
