I’m having troubles attaching multiple SSL profiles on 1 virtual server since i’m changing the SSL Ciphers.
0107157c:3: Selected client SSL profiles do not match security policies for Virtual Server /Common/
Already checked this article: myF5
It are 5 different client SSL profiles.
3 wildcard & 2 normal certificates. It is working at this moment without any problems and i putted 1 of them as a Default SNI in the ssl profile.
1) *.domainname.com (default SNI profile) 2) *.olddomainname.com 3) *.x.domainname.com 4) y.domainname.com 5) z.domainname.com
With the new SSL profiles with different allow of ciphers i’m unable to attack more then 2 profiles. 1 with SNI and 1 without SNI.
Any idea how to solve this? With All the other Virtual servers with 2 or 1 SSL profiles i’m having no problems at all. Is it a problem with 1 of the SSL ciphers that is giving an issue?
I put this SSL cipher string into the new client SSL
ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA:ECDHE-RSA-AES256-CBC-SHA:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES128-CBC-SHA:AES256-GCM-SHA384:AES128-GCM-SHA256:AES256-SHA256:AES256-SHA:AES128-SHA256:AES128-SHA:-SSLv3:-TLSv1:-DTLSv1:!RSA
Thanks in advance. kind regards
