Problems with LTM VE
Hi All,
I have Installed LTM VE 11.1 on Vmware Workstation 8.0.3. Host machine is Windows 7 Enterprise 64-bit. I have the following network configuration on Workstation.
VMnet0
Bridged
VMnet1
Host-only
Select “Connect a host virtual adapter to the network”
Subnet IP: 10.60.0.0
Subnet Mask: 255.255.255.0
VMnet2
Host-only
Subnet IP: 10.70.0.0
VMnet3
Host-only
Subnet IP: 10.80.0.0
Vmnet3 is internal vlan, where i have 3 instances of easyPHP based Webservers, (10.80.0.2/3 &4) on Port 8080, with a small php script. Test Successfully.
I have now created a pool of these servers, and created a Virtual Server(10.70.0.201 on Port 80) in the same pool. However, I cannot browse the webpage 10.70.0.201. Virtual Server Settings are as follows:
a. HTTP profile set to “http”
b. SNAT Pool set to “Auto Map”
c. Default Pool set to the pool you created in the first step
d. Default Persistence Profile set to “Cookie”
Please assist at the earliest, I need to do demo on this.
Disconnect VMnet1 and VMnet2 in VMWare Workstation and test connectivity between the BIG-IP SelfIP and the web servers. The interfaces may not be connected to the networks you think they are. That would be my first guess.
Sorry I forgot to tell you, I am able to ping the virtual servers… from Host and Big-IP VE. Please assist.
