Problems with a rewrite. Please help
Hi, I’ve been asked to write an irule that will intercept anything with a uri that begins with /upload and remove the /upload.
Also, the rule needs to rewrite the host from whatever it is to be the hostname of the server in the pool that it gets served by and to also have :8080 added to it.
https://images.blah.com/upload/document-delivery/uploadfile
to be rewritten to
http://hostname:8080/document-delivery/uploadfile
So far I have come up with this:
set origuri [HTTP::uri]
if { $origuri starts_with “/upload” } {
HTTP::uri [string range $origuri 7 end]
pool pool1
which I thought would at least remove the /upload part of the URI but it doesn’t seem to.
Any help is greatly appreciated.
Hi David,
Here’s an example which rewrites the host header value based on the selected server IP address:
You could modify that to change the URI as you need to. In pre-v11, the [HTTP::uri] value is cached within the same event. The actual value sent to the pool is updated though. If you want to log the updated value, you can do this in a later HTTP_REQUEST event:
   log local0. "[IP::client_addr]:[TCP::client_port]: Original request: [HTTP::host][HTTP::uri]"
   if { [HTTP::uri] starts_with "/upload" } {
      HTTP::uri [string range [HTTP::uri] 7 end]
      pool pool1
when HTTP_REQUEST priority 501 {
   log local0. "[IP::client_addr]:[TCP::client_port]: Current request: [HTTP::host][HTTP::uri]"
Aaron
