Hello,
we have a BigIP with internal and external network.
We need two different routing tables for
- external traffic connection to the VIPs and
- internal traffic from the BigIPs to the nodes.
So I created in /common a route domein (%1) as child of the default domain. I put the external self IPs into %1 and created routes for the external world.
The internal self IPs and the nodes are in domain 0 (no %1).
The BigIP can see the nodes (all monitors of all nodes show “up”.
I can connect from external to the VIPs, but I do not get a valid HTML answer. E.g.
telnet mybigip.example.com 80
Connected to mybigip.example.com.
Escape character is '^]'.
GET / HTTP/1.1
Host: mybigip.example.com
Connection: close
Connection closed by foreign host.
I monitored the internal and external interfaces with tcpdump. I can only see the monitoring traffic to the nodes, but nothing related to my request.
The same configuration without second routing domain is working fine.
Has anyone a suggestion? Thanks in advance, Steffen
