I downloaded the iControl 4.6.2 sdk for Windows. The file created by the download is : iControl-4[1][1].6.2.zip. When I try to unzip this file winZip indicates that there is an error with the file.
The error is : End-of-central-directory signature not found. Either this file is not a Zip file, or it constitutes one disk of a multi-part Zip file.
Am I doing something wrong? Anyone else having this problem?
Thanks,
Keith
Keith,
I just downloaded the same SDK, and was able to extract the ZIP file successfully. I suspect you had some network disruption or connectivity problem that might have corrupted the file. Please give it another try.
Loc
The problem could be with the size of the file and a network hiccup between our server and your machine. Try downloading the unix version (.tar.gz). This is about 1/5th of the size and is able to be opened with Winzip on windows.
-Joe
