Problems about mac-masquerade implementation
we suspect that we´re having mac-masquerade problems on our Production F5.
I explain the problem:
1-We created a new vlan on our f5.
2-After this, we configured a mac-masquerade* on it.
3-Then, we configured a physical IP address (self-ips) and fa loating one for this vlan.
4-Finally, we executed pings from a PC, placed on this new vlan, to the floating ip address, and it didn´t work.
5-After testing several changes on F5 configuration, we changed the mac-masquerade, and… surprise!!! it worked!!!..
6-Besides, we changed mac-masquerade again to the first mac-masquerade* and …
it went on working!!!
Would you mind helping us to find a reasonable explanation?..
Regards.
A. Diezma.
Additional clue: We executed “tcpdump” on F5 and we saw the message “…(oui known)”…or something like that. Sorry for the mess, but we couldn´t capture the result of this command :frowning:
Which MAC address did you pick?
sol7214: Configuring MAC masquerading
sol3523: Choosing a unique Media Access Control (MAC) address for MAC masquerade
Did you clear the ARP cache on connected switches when you enabled masquerading?
Aaron
Mac-masquerade= 0:1:0:2:31:8
Yes, we cleared the ARP cache on connected switches when you enabled masquerading.
Best Regards
OUI unknown just indicates that the first half of the MAC address wasn’t recognized by tcpdump. I don’t think that is a factor in the issue.
I imagine the best way to troubleshoot this would be to retry the process during a maintenance window. You could open a proactive case with F5 Support to have an engineer on a Webex while you test.
Aaron
