probleme java with f5 bigip
Good morning, after updating Google Chrome to Version 122… applications are no longer accessible via f5
We’re running into the same issue, both Edge and Chrome updating to v122 breaks the URI webtop link to the application. Dev Tools show the cache-fm-Modern.js breaking.
If “acessible via f5” you mean APM access policy, I have the same problem. @danielm1 suggested this: myF5 and for me that really make sense. Tomorrow I will give it a go.
I was just coming back to report my findings- I don’t think that we need to have caching enabled for our application, and the js error stopped when I turned off caching. We (as in my team and I) try to practive Read Only Fridays, but your link looks like a better solution long term.
Unfortunately turning cache off didnt work for me ): I will let you guys know if my solution worked
Just giving you guys a feedback. myF5 worked like a charm for me
