Hey everyone!
I tried to deploy VMware Horizon using the latest iApp but when I selected to use AFM’s recommended settings, I was hit with the following error:
script did not successfully complete: (can't read "app": no such variable
while executing
"iapp_conf create security firewall policy ${app}_firewall_udp rules replace-all-with \{ acceptPackets \{ action accept log no ip-protocol udp st..."
invoked from within
"subst $substa_out"
invoked from within
"if { [info exists [set substa_in]] } {
set substa_out [subst $$substa_in]
set substa_out [subst $substa_out]
("uplevel" body line 3)
invoked from within
"uplevel {
append ::substa_debug "\n$substa_in"
(procedure "iapp_substa" line 9)
invoked from within
"iapp_substa ::firewall_arr($::allow_afm,$::do_firewall,$::new_firewall,udp)"
(procedure "create_view_udp_vs" line 7)
invoked from within
"create_view_udp_vs 4172 pcoip"
invoked from within
"subst $apm_virtuals($do_apm,$do_smart)" line:1920)
I tried to downgrade to 1.5.5, same story. It started to work when I used 1.5.4 instead.
Has anyone seen this issue before? Must be some kind of bug in the template.
