Problem with Sync
Hello,
I am having a problem when trying to sync my config from my active unit to my standby unit using ConfigSync or ‘bigpipe config sync all’ command via CLI;
The following message displays;
[root@f5bigip:Active] config b config sync all
Checking configuration on local system and peer system…
Peer’s IP address: 192.x.x.x
Synchronizing Master Keys…
Saving active configuration…
Configsync Mode: Push
Transferring UCS to peer…
Installing UCS on peer…
OperationFailed exception:
Primary error : 16908289
Secondary error: 0
Error text : Error installing configuration
Obtaining results of remote configuration installation…
BIGpipe parsing error:
012e0028:3: There is no valid configuration to save.
Please check the logs for licensing, configuration, or other problems.
Current configuration backed up to /var/local/ucs/cs_backup.ucs.
Product : BIG-IP
Version : 10.1.0
Hostname: UCS : f5bigip
System: f5bigip2
Installing --shared-- configuration on host f5bigip2
Installing configuration…
Installing ASM configuration…
Post-processing…
BIGpipe static route creation error:
01070330:3: Static route gateway 10.x.x.x is not directly connected via an interface.
Reading configuration from /config/low_profile_base.conf.
Reading configuration from /defaults/config_base.conf.
Reading configuration from /config/bigip_sys.conf.
Reading configuration from /config/bigip_base.conf.
Reading configuration from /usr/share/monitors/base_monitors.conf.
Reading configuration from /config/profile_base.conf.
Reading configuration from /config/daemon.conf.
Reading configuration from /config/bigip.conf.
Reading configuration from /config/bigip_local.conf.
Loading the configuration …
Loading ASM configuration…
WARNING: There were one or more errors detected during installation.
Check the error messages and take the proper actions if needed.
ERROR: UCS installation failed.
Operation aborted.
/tmp/configsync.spec: Error installing package
Config install aborted.
01110001:3: Error running config install
Here is the tail of /var/log/ltm
Nov 22 18:37:33 local/f5bigip2 info bigpipe: Begin config install operation: /var/local/ucs/__sync_remote__.ucs
Nov 22 18:37:36 local/f5bigip2 notice logger: /usr/bin/perl /usr/local/bin/im -exclfrom -q -force /var/local/ucs/__sync_remote__.ucs ==> /usr/bin/bigstart stop named
Nov 22 18:37:36 local/f5bigip2 notice mcpd[3241]: 01070410:5: Removed subscription with subscriber id named
Nov 22 18:37:38 local/f5bigip2 notice logger: /usr/bin/perl /usr/local/bin/im -exclfrom -q -force /var/local/ucs/__sync_remote__.ucs ==> /usr/bin/bigstart stop zrd
Nov 22 18:37:43 local/f5bigip2 info mcpd[3241]: 01070465:6: Resuming log processing at this invocation; held 331 messages.
Nov 22 18:37:43 local/f5bigip2 warning mcpd[3241]: 01070465:4: DB changed: failover.nettimeoutsec, configsync needed
Nov 22 18:37:43 local/f5bigip2 warning mcpd[3241]: 01070465:4: DB changed: failover.netretrylimit, configsync needed
Nov 22 18:37:43 local/f5bigip2 warning mcpd[3241]: 01070465:4: DB changed: failover.failbackdelay, configsync needed
Nov 22 18:37:43 local/f5bigip2 warning mcpd[3241]: 01070465:4: DB changed: failover.activemode, configsync needed
Nov 22 18:37:43 local/f5bigip2 warning mcpd[3241]: 01070465:4: DB changed: failover.manfailback, configsync needed
Nov 22 18:37:43 local/f5bigip2 info mcpd[3241]: 01070465:6: Per-invocation log rate exceeded; throttling.
Nov 22 18:37:43 local/f5bigip2 info mcpd[3241]: 01070417:6: Per-invocation log rate exceeded; throttling.
Nov 22 18:37:43 local/f5bigip2 info mcpd[3241]: 010712e9:6: Resuming log processing at this invocation; held 8 messages.
Nov 22 18:37:43 local/f5bigip2 warning mcpd[3241]: 010712e9:4: failover.netretrylimit is not in BigDB.dat.
Nov 22 18:37:43 local/f5bigip2 warning mcpd[3241]: 010712e9:4: pva.acceleration.strategy is not in BigDB.dat.
Nov 22 18:37:43 local/f5bigip2 warning mcpd[3241]: 010712e9:4: compression.hardware.ratio is not in BigDB.dat.
Nov 22 18:37:43 local/f5bigip2 warning mcpd[3241]: 010712e9:4: serial.console.speed is not in BigDB.dat.
Nov 22 18:37:43 local/f5bigip2 warning mcpd[3241]: 010712e9:4: failover.sslhardware is not in BigDB.dat.
Nov 22 18:37:43 local/f5bigip2 info mcpd[3241]: 010712e9:6: Per-invocation log rate exceeded; throttling.
Nov 22 18:37:43 local/f5bigip2 info mprov: Invoked as: MPROV (pid=29678) --file /var/run/config/.mprov.temp --quiet --list
Nov 22 18:37:47 local/f5bigip2 info mprov: Provisioning (validation) successful.
Nov 22 18:37:49 local/f5bigip2 notice logger: /usr/bin/perl /usr/local/bin/im -exclfrom -q -force /var/local/ucs/__sync_remote__.ucs ==> /usr/bin/bigstart start named
Nov 22 18:37:49 local/f5bigip2 notice logger: /usr/bin/perl /usr/local/bin/im -exclfrom -q -force /var/local/ucs/__sync_remote__.ucs ==> /usr/bin/bigstart start zrd
Nov 22 18:37:49 local/f5bigip2 info mcpd[3241]: 01070417:6: Resuming log processing at this invocation; held 338 messages.
Nov 22 18:37:50 local/f5bigip2 notice sod[3267]: 010c0044:5: Command: running disable zrd bigstart.
Nov 22 18:37:52 local/f5bigip2 err mcpd[3241]: 01070330:3: Static route gateway 10.130.4.1 is not directly connected via an interface.
Nov 22 18:37:59 local/f5bigip2 info mcpd[3241]: 01070417:6: Per-invocation log rate exceeded; throttling.
Nov 22 18:38:01 local/f5bigip2 info mcpd[3241]: 01070417:6: Resuming log processing at this invocation; held 1 messages.
Nov 22 18:38:01 local/f5bigip2 info mcpd[3241]: 01070417:6: Per-invocation log rate exceeded; throttling.
Nov 22 18:38:02 local/f5bigip2 err bigpipe[27817]: 01110001:3: Error running config install
Nov 22 18:38:03 local/f5bigip2 info mcpd[3241]: 01070417:6: Resuming log processing at this invocation; held 1 messages.
[root@f5bigip2:Standby] config
Can anyone help at all?
Regards,
Ed
Have you compared the non-shared configuration between devices at all and made sure the required objects are present? Things such as;
•VLANs
•Non floating Self IP Addresses
•Device Failover Configuration
This in particular seems to suggest something is missing from the second device: “01070330:3: Static route gateway 10.x.x.x is not directly connected via an interface”
As an alternative, you could try manually saving a UCS from device 1 and trying to install it on device 2 or a test device and seeing if you get any further errors.
